Using Power Management
To Start dtpower From the Command Line
  1. Become superuser by typing:
    example% su
    Password: root_password
    You must become superuser before you can modify any settings in the Power Management software. Otherwise, the dtpower window only allows you to check current system power settings.
  2. Start dtpower by typing:
    example% /usr/openwin/bin/dtpower &
