Using Power Management
System AutoShutdown and AutoWakeup Controls
You can specify, through the dtpower window, the timing conditions that will cause your system to shut down automatically after being idle. This feature is called AutoShutdown.
If you have a sun4u desktop machine, you also can set your system to power on automatically at a specified time each day. This feature is called AutoWakeup.
Note -
Be sure to read "Choosing to Use Power Management" before changing the AutoShutdown settings.
AutoShutdown uses the Suspend feature to automatically power off your system. When the system powers up again, it resumes in the same state as when it was suspended.
Through the dtpower window, you can activate or deactivate the AutoShutdown and AutoWakeup features, and specify the following time values:
Note -
AutoWakeup does not occur after you Suspend a system manually; it can occur only after AutoShutdown.
