To optimize data processing in the master index application, you can define additional indexes for the database tables that store object data. Best practice is to define indexes for each field used for searching, blocking, or matching. You can define these indexes in the Create User Indexes file or create a new script. Before you begin this step, complete Step 2: Create a Master Index Database and User.
Under the master index project in the Projects window, expand Database Scripts and then open the Create User Indexes file in the NetBeans editor.
Do any of the following:
Save and close the file.
Continue to Step 4: Define Master Index External Systems.
