If the parent object information for an object profile changes, you can update the information in either the SBR or the affected system record. If you update the system record, then the survivor calculator determines what changes, if any, should be made to the SBR. You must have overwrite permissions to update the SBR directly.
Using one of the search methods described in Searching for Object Profiles on the EDM, display the object profile you want to modify on the View/Edit page.
Do one of the following:
Modify the fields in the right portion of the page.
If you are working in the SBR, make sure the overwrite check box to the left of the field is selected for each field you modify.
When you are done modifying information, click Commit.
The page refreshes, and, if you modified a system record, the SBR is recalculated based on the new information.
