The following table lists and describes the XML elements that define the configuration of the Reports page on the EDM.
Table 1 Reports Page Configuration Elements|
Element |
Description |
The name of the type of object on which to report (this must be the parent object). |
A name for the report pages. This name appears on tab label associated with the report pages on the EDM. |
The URL to the entry page of the reports pages. This element should not be modified. |
The number of fields to display in each row of the Reports Search page. |
The following table lists and describes the XML elements that define the reports run from the EDM.
Table 2 Reports Configuration Elements
