To illustrate how the order property works, consider the simple tree structure shown in the following diagram, where a is an element node, b is a non-repeating field node, and c is a repeating field node. The value set for the order property allows the field nodes to appear as shown in following table.
Value |
Allowed Node Order |
sequence |
b, c1, c2 |
any |
b, c1, c2, or c1, c2, b |
mixed |
b, c1, c2, or c1, c2, b, or c1, b, c2 |
