To optimize data processing in the master index application, you can define additional indexes for the database tables that store object data. Best practice is to define indexes for each field used for searching, blocking, or matching. You can define these indexes in create.sql or create a new script. Before you begin this step, complete Step 2: Create a Master Index Database and User.
Do one of the following:
Do any of the following:
Save and close the file.
Continue to Step 4: Define Master Index External Systems.
