A SQL script is automatically created to insert the systems you specified in the wizard. These statements are provided in systems.sql in the master index project. Before you begin this step, complete Step 2: Create a Master Index Database and User and, optionally, Step 3: Define Master Index Database Indexes.
Do one of the following:
For each system, create an INSERT statement using the column descriptions in Master Index Database Table Description for sbyn_systems to define the VALUES clause.
For example:
INSERT into sbyn_systems (systemcode, description, status, id_length, format, input_mask, value_mask, create_date, create_userid) VALUES (’ARS’, ’Automated Registration System’, ’A’, 8, ’[0-9]{8}’, ’DD-DDD-DDD’, ’DD^DDD^DDD’, sysdate, 'admin’); |
Delete any default INSERT statements you do not need.
Save and close the file.
Continue to Step 5: Define Master Index Code Lists.
