Certain configuration information is defined automatically in the implementation details section of midm.xml based on information you specify in the wizard. Other information in this section must be customized by modifying the XML file directly.
You can customize the implementation details by performing any of the following tasks.
The MIDM must know the name of the Master Controller interface for the Sun Master Index implementation. Only change this value if you create a custom Master Controller.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click midm.xml.
The file opens in the NetBeans XML editor.
Scroll to the impl-details element, and then to the master-controller-jndi-name element.
Modify the value of the master-controller-jndi-name element to the name of the Master Controller JNDI class for your server.
For example:
<master-controller-jndi-name>ejb/CustomerMasterController </master-controller-jndi-name> |
Save and close the file.
The MIDM must know the name of the class used to generate reports for the MIDM. Only change this value if you create a custom report generator.
Scroll to the impl-details element, and then to the reportgenerator-jndi-name element.
Modify the value of the reportgenerator-jndi-name element to the name of the report generator JNDI class to use.
For example:
reportgenerator-jndi-name>ejb/CustomerReportGenerator </reportgenerator-jndi-name> |
Validation services verify processing codes for data entered into the master index database. Only change the names of the validation services if you created custom code list validators.
Scroll to the impl-details element, and then to the validation-service-jndi-name element.
To change the name of the validator for processing codes stored in sbyn_common_header, modify the value of the validation-service-jndi-name element to the name of the JNDI class used for validation.
For example:
<validation-service-jndi-name>ejb/CustomerCodeLookup </validation-service-jndi-name> |
To change the name of the validator for processing codes stored in sbyn_user_code, modify the value of the usercode-jndi-name element to the name of the JNDI class used for validation.
For example:
<usercode-jndi-name>ejb/CustomerUserCodeLookup </usercode-jndi-name> |
When you first implement Sun Master Index, you might want to view detailed debug information until you are certain the application is working as required. You can set debug options in the implementation details.
Scroll to the impl-details element, and then to the debug-flag element.
Modify the value of the debug-flag element to indicate whether you want debug information logged.
For example:
<debug-flag>true</debug-flag> |
Specify true to log debug information; specify false to turn logging off.
Modify the value of the debug-dest element to indicate where to print debug information.
For example:
<debug-dest>console</debug-dest> |
Specify console to log debug information to a monitor; specify file to print to a file.
If you implement a custom class to define field masking logic, you must specify the new class in the implementation details. The custom class must be created as a custom plug-in in the Sun Master Index project. This class can be used to mask the value of any field for which the is-sensitive element is set to “true”.
Scroll to the impl-details element.
Change the value of the object-sensitive-plug-in-class element to the name of the custom class.
For example:
<object-sensitive-plug-in-class> com.sun.mdm.index.user.customfieldmasker </object-sensitive-plug-in-class> |
