Several match and standardization engine configuration files are included in the project tree. You can customize matching logic and standardization information for the match and standardization engines by modifying these files. The match configuration file, which defines and configures the comparator functions, can be modified using the Master Index Configuration Editor or the NetBeans text editor. The standardization files, which provide information to the standardization engine about how data should be parsed and normalized, can be modified using the text editor.
For information about the structure of these files and how they can be modified, see Understanding the Master Index Match Engine and Understanding the Master Index Standardization Engine.
