Which properties appear in the dialog depends upon whether the client is a producer or consumer.
Table 2 JMS Client Basic Configuration
Properties|
Property |
Applies to |
Description |
Transaction mode |
All producers |
Specifies whether messages for this session use Transacted or XA mode. For consumers, the default is always XA; otherwise, the default is Transacted. |
Delivery mode |
All producers |
Specifies whether the messages for this JMS connection are persistent or non-persistent. The default is Persistent. |
Priority |
All producers |
Specifies the message priority. Allowed values are 0 - 9; the default is 4. |
Idle timeout |
All producers |
Specifies the number of seconds to wait before returning a connection to the pool. The default is 30 seconds. |
Maximum Pool Size |
All producers |
Specifies the maximum number of connections to be made to the message server. The default is 32. |
Maximum Wait Time |
All producers |
Specifies the maximum amount of milliseconds to wait for acquiring a connection before throwing an exception. The default is 30000 milliseconds. |
Steady Pool Size |
All producers |
Specifies the minimum and initial number of connections maintained in the pool. The default is 4. |
Message selector |
All consumers |
Specifies a message selector. |
Concurrency |
All consumers |
Specifies whether the message consumers uses connection consumer or serialized processing. The default is Serial mode. |
