The DB2 Connect Adapter configuration parameters, accessed from the Environment Explorer tree, are organized into the following sections:
Outbound DB2 Connect non-Transactional Adapter - JDBC Connector Settings
Outbound DB2 Connect non-Transactional Adapter - Connection Retry Settings
Outbound DB2 Connect Type 4 Adapter - JDBC Connector Settings
Outbound DB2 Connect Type 4 Adapter - Connection Retry Settings
Outbound DB2 Connect non-Transactional Type 4 Adapter - JDBC Connector Settings
Outbound DB2 Connect non-Transactional Type 4 Adapter - Connection Retry Settings
Outbound DB2 Connect Type 4 XA Adapter - JDBC Connector Settings
Outbound DB2 Connect Type 4 XA Adapter - Connection Retry Settings
The Inbound DB2 Connect Adapter > Parameter Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 14 Inbound DB2 Connect Adapter - Parameter Settings.|
Name |
Description |
Required Value |
Description |
Enter a description for the database. |
A valid string. The default is DB2 Connect DriverManager. |
DatabaseName |
Specifies the name of the database instance used on the Server. |
Any valid string. |
User |
Specifies the user name that the Adapter uses to connect to the database. |
Any valid string. |
Password |
Specifies the password used to access the database. |
Any valid string. |
The Outbound DB2 Connect Adapter > JDBC Connector Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 15 Outbound DB2 Connect Adapter - JDBC Connector Settings|
Name |
Description |
Required Value |
Description |
A valid string. The default value is DB2 Connect Connection Pool Datasource. |
DatabaseName |
Any valid string. |
User |
Any valid string. |
Password |
Any valid string. |
DriverProperties |
Use the JDBC driver that is shipped with this Adapter. Often times the DataSource implementation needs to execute additional methods to assure a connection. You must identify the additional methods in the Driver Properties. |
Any valid delimiter. Valid delimiters are: “<method-name-1>#<param-1>#<param-2>##.........<param-n>##<method-name-2>#<param-1>#<param-2>#........<param-n>##......##”. For example: To obtain a DB2 Connect trace, give the method a string for the email “settraceLevel#-1##settraceFile#c:/temp/db2trace.txt##” |
Delimiter |
This is the delimiter character to be used in the DriverProperties prompt. |
The default is #. |
MinPoolSize |
The minimum number of physical connections the pool keeps available at all times. 0 (zero) indicates that there are no physical connections in the pool and new connections are created as needed. |
A valid numeric value. The default is 0. |
MaxPoolSize |
The maximum number of physical connections the pool keeps available at all times. 0 (zero) indicates that there is no maximum. |
A valid numeric value. The default is 10. |
MaxIdleTime |
The maximum number of seconds that a physical connection may remain unused before it is closed. 0 (zero) indicates that there is no limit. |
The Outbound DB2 Connect Adapter > Connection Retry Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 16 Outbound DB2 Connect Adapter - Connection Retry Settings|
Name |
Description |
Required Value |
ConnectionRetries |
Specifies the number of retries to establish a connection with the DB2 Connect database upon a failure to acquire one. |
an integer indicating the number of attempts allowed to establish a connection. The configured default is 0. |
ConnectionRetry Interval |
Specifies the milliseconds of pause before each attempt to access the database. This setting is used in conjunction with the Connection Retries setting. For example: In the event that the Adapter cannot connect to the Database, the Adapter will try to reconnect to the database 10 times in 5 seconds intervals when the Connection Retries is 10 and the Connection Retry Interval is 5000. |
An integer indicating the configured length of the time (in milliseconds) before each reattempt to access the destination file. The configured default is 1000 (1 second). |
The Outbound DB2 Connect non-Transactional Adapter > JDBC Connector Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 17 Outbound DB2 Connect non-Transactional Adapter - JDBC Connector Settings|
Name |
Description |
Required Value |
Description |
A valid string. The default value is DB2 Connect non-Transactional Connection Pool Datasource. |
DatabaseName |
Any valid string. |
User |
Any valid string. |
Password |
Any valid string. |
DriverProperties |
Delimiter |
The default is #. |
MinPoolSize |
MaxPoolSize |
MaxIdleTime |
The Outbound DB2 Connect non-Transactional Adapter > Connection Retry Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 18 Outbound DB2 Connect non-Transactional Adapter - Connection Retry Settings|
Name |
Description |
Required Value |
ConnectionRetries |
The Outbound DB2 Connect XA Adapter > JDBC Connector Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 19 Outbound DB2 Connect XA Adapter - JDBC Connector Settings|
Name |
Description |
Required Value |
Description |
A valid string. The default value is DB2 Connect XA Datasource. |
DatabaseName |
Any valid string. |
User |
Any valid string. |
Password |
Any valid string. |
DriverProperties |
Delimiter |
The default is #. |
MinPoolSize |
MaxPoolSize |
MaxIdleTime |
The Outbound DB2 Connect XA Adapter > Connection Retry Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 20 Outbound DB2 Connect XA Adapter - Connection Retry Settings|
Name |
Description |
Required Value |
ConnectionRetries |
The Inbound DB2 Connect Type 4 Adapter > Parameter Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 21 Inbound DB2 Connect Type 4 Adapter - Parameter Settings|
Name |
Description |
Required Value |
Description |
ServerName |
Specifies the host name of the external database server. |
Any valid string. |
PortNumber |
Specifies the I/O port number on which the server is listening for connection requests. |
A valid port number. The default is 446. |
DatabaseName |
Any valid string. |
User |
Any valid string. |
Password |
Any valid string. |
The Outbound DB2 Connect Type 4 Adapter > JDBC Connector Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 22 Outbound DB2 Connect Type 4 Adapter - JDBC Connector Settings|
Name |
Description |
Required Value |
Description |
A valid string. The default value is DB2 Connect Type 4 Connection Pool Datasource. |
ServerName |
Any valid string. |
PortNumber |
DatabaseName |
Any valid string. |
User |
Any valid string. |
Password |
Any valid string. |
DriverProperties |
Delimiter |
The default is #. |
MinPoolSize |
MaxPoolSize |
MaxIdleTime |
The Outbound DB2 Connect Type 4 Adapter > Connection Retry Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 23 Outbound DB2 Connect Type 4 Adapter - Connection Retry Settings|
Name |
Description |
Required Value |
ConnectionRetries |
The Outbound DB2 Connect non-Transactional Type 4 Adapter > JDBC Connector Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 24 Outbound DB2 Connect non-Transactional Type 4 Adapter - JDBC Connector Settings|
Name |
Description |
Required Value |
Description |
ServerName |
Any valid string. |
PortNumber |
DatabaseName |
Any valid string. |
User |
Any valid string. |
Password |
Any valid string. |
DriverProperties |
Delimiter |
The default is #. |
MinPoolSize |
MaxPoolSize |
MaxIdleTime |
The Outbound DB2 Connect non-Transactional Type 4 Adapter > Connection Retry Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 25 Outbound DB2 Connect non-Transactional Type 4 Adapter - Connection Retry Settings|
Name |
Description |
Required Value |
ConnectionRetries |
The Outbound DB2 Connect Type 4 XA Adapter > JDBC Connector Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 26 Outbound DB2 Connect Type 4 XA Adapter - JDBC Connector Settings|
Name |
Description |
Required Value |
Description |
A valid string. The default value is DB2 Connect Type 4 XA Datasource. |
ServerName |
Any valid string. |
PortNumber |
DatabaseName |
Any valid string. |
User |
Any valid string. |
Password |
Any valid string. |
DriverProperties |
Delimiter |
The default is #. |
MinPoolSize |
MaxPoolSize |
MaxIdleTime |
The Outbound DB2 Connect Type 4 XA Adapter > Connection Retry Settings section of the DB2 Connect Environment properties, contains the top-level parameters displayed in the following table.
Table 27 Outbound DB2 Connect Type 4 XA Adapter - Connection Retry Settings|
Name |
Description |
Required Value |
ConnectionRetries |
