DB2 Connect Adapter Outbound Connectivity
Map Properties
The Outbound configuration parameters, accessed from the Connectivity
Map, are organized into the following sections:
DB2 Connect Type 4 Adapter - Outbound JDBC Connector
Settings
The JDBC Connector Settings section
in the DB2 Connect Type 4 Adapter Outbound
Connectivity Map properties contains the top-level parameters displayed in
the following table.
Table 1–3 DB2 Connector Type 4 Adapter - Outbound
Name
Description
Required Value
Description
Enter a description for the database.
A valid string. The default is DB2 Connect Type
4 Connection Pool Datasource.
ClassName
Specify the Java class in the JDBC driver that is used to implement the ConnectionPoolDataSource
interface for a Type 4 driver.
A valid class name.
The default is com.ibm.db2.jcc.DB2ConnectionPoolDataSource.
DB2 Connect XA Adapter - Outbound JDBC Connector
Settings
in the DB2 Connect XA Adapter Outbound
Table 1–4 DB2 Connect XA Adapter - Outbound JDBC
Connector Settings
Name
Description
Required Value
Description
A valid string. The default is DB2 Connect XA
Datasource.
ClassName
interface for a XA driver.
A valid class name.
The default is COM.ibm.db2.jdbc.DB2XADataSource.
DB2 Connect Adapter - Outbound JDBC Connector Settings
in the DB2 Connect Adapter Outbound Connectivity
Map properties contains the top-level parameters displayed in the following
table.
Table 1–5 DB2 Connect Adapter - Outbound JDBC
Connector Settings
Name
Description
Required Value
Description
A valid string. The default is DB2 Connect Connection
Pool Datasource.
ClassName
interface.
A valid class name.
The default is COM.ibm.db2.jdbc.DB2ConnectionPoolDataSource.
DB2 Connect non-Transactional Type 4 Adapter - Outbound
in the DB2 Connect non-Transactional Type 4 Adapter Outbound
Table 1–6 DB2 Connect non-Transactional Type 4
Name
Description
Required Value
Description
ClassName
interface for a non-transactional Type 4 driver.
A valid class name.
DB2 Connect Type 4 XA Adapter - Outbound JDBC Connector
Settings
in the DB2 Connect Type 4 XA Adapter Outbound
Table 1–7 DB2 Connect Type 4 XA Adapter - Outbound
Name
Description
Required Value
Description
4 XA Datasource.
ClassName
interface for a Type 4 XA driver.
A valid class name.
The default is com.ibm.db2.jcc.DB2XADataSource.
DB2 Connect non-Transactional Adapter - Outbound
in the Outbound DB2 Connect non-Transactional Adapter Outbound
Table 1–8 DB2 Connect non-Transactional Adapter
Name
Description
Required Value
Description
A valid string. The default is DB2 Connect non-Transactional
ClassName
interface for a non-transactional driver.
A valid class name.
