This topic introduces you to the United States Patient Solution. The purpose is to help you solve a business problem by providing you with a template that is configurable to your specific requirements, enabling you to create a single patient solution that includes all required and optional bits of information that are specific to each and every patient in your healthcare system. After the database is completed and operational, you will have a patient model that eliminates errors inherent in systems that have patient information spread throughout a number of hard copy and electronic systems that is easy to access and use.
As this template was specifically designed for United States healthcare, use it with the Master Data Management (MDM) product suite, specifically the Master Index portion of MDM, when implementing your system.
The patient solution was created to enable you to set up your healthcare solution without having to create everything from scratch. When studying the solution, observe that it addresses all pertinent bits of patient information, including insurance, medical condition, and medications. Benefits for using the solution include:
Set up of patient solution template using MDM's Master Index
Enables easy alteration of the template to suit your requirements
Combines and standardizes records into a single patient database
Enables merging of disparate legacy patient databases
Completed United States Patient Solution
Enables web services connectivity
Enables fully-functioning patient knowledge base
Reduces patient identity errors
Increases reliability while reducing cost
For the link to the United States Patient Solution template, go to https://open-dm-mi.dev.java.net/docs/solutions/usa-patient.html.
See Also
