United Kingdom Patient Solution Using MDM
ProcedureTo Create a Database for the United Kingdom Patient Solution
Before You Begin
The Oracle scripts that come with the solution create a user identified as uk. They are located in the Solutions\NB\MI\project\UKPatient\sca\source\DatabaseScript directory.
  1. As a SYSDBA user run the createuser-uk.sql script.
  2. As the uk user, with a password of uk, run the following scripts.
    Tip –
    Run the create.sql script first.
    • create.sql
    • codelist.sql
    • systems.sql
    • createIndexes.sql
    • createUserCodeData.sql
See Also
