The Scheduler Binding Component includes the following features:
Triggers are created using a binding component powered by OpenSymphony Quartz, providing extensive configuration options.
The Scheduler wizard provides three trigger options: Simple, Cron, and Hybrid, which allow you to easily configure the date and time that a trigger fires, as well as the duration and interval.
Application configuration parameters allow you to easily reconfigure existing projects at runtime.
The Scheduler allows you to monitor statistics for the component and provides logging and alerts for key processes.
