Java CAPS provides shortcuts to the executable files that start the various components. To start and stop Java CAPS after the initial installation, navigate to the Java CAPS install directory or to the directory where the component is installed that you want to start or stop. Run the appropriate command. The commands are listed at Starting and Stopping Java CAPS in Using the Java CAPS 6 Installation GUI.
