The fault monitor for Sun Cluster HA for Sun Java System Application Server EE (HADB) is contained in the resource that represents Sun Java System Application Server EE (HADB). You create this resource when you register and configure Sun Cluster HA for Sun Java System Application Server EE (HADB). For more information, see Registering and Configuring the Sun Cluster HA for Sun Java System Application Server EE (HADB).
System properties and extension properties of this resource control the behavior of the fault monitor. The default values of these properties determine the preset behavior of the fault monitor. The preset behavior should be suitable for most Sun Cluster installations. Therefore, you should tune the fault monitor only if you need to modify this preset behavior.
For more information, see the following sections.
Appendix A, Properties for Sun Cluster HA for Sun Java System Application Server EE (Supporting HADB Versions as of 4.4) in this guide for a detailed description of the extension properties for the SUNW.hadb_ma resource type
