| <?xml version="1.0" encoding="UTF-8"?> <xs:schema targetNamespace="/var/opt/SUNWldom/envelope" xmlns:ovf="/var/opt/SUNWldom/envelope" xmlns:xs="http://www.w3.org/2001/XMLSchema"> <xs:import namespace="http://www.w3.org/XML/1998/namespace" schemaLocation="http://www.w3.org/2001/xml.xsd"/> <!-- The base class for a section. Subclassing this is the most common form of extensibility --> <xs:complexType name="Section_Type" abstract="true"> <xs:sequence> <!-- The info element specifies the meaning of the section. This is typically shown if the section is not understood by the importer --> <xs:element name="Info" type="ovf:Info_Type" minOccurs="0" maxOccurs="unbounded"/> </xs:sequence> <!-- Whether the import should fail or not, if the section is not understood --> <xs:attribute name="required" type="xs:boolean" use="optional"/> <xs:anyAttribute namespace="##any"/> <!-- Subtypes defines more specific elements --> </xs:complexType> <!-- A basic type for a localizable string --> <xs:complexType name="Info_Type"> <xs:simpleContent> <xs:extension base="xs:string"> <xs:attribute ref="xml:lang"/> </xs:extension> </xs:simpleContent> </xs:complexType> </xs:schema> |
