If both internal changes and the addition of a new interface has occurred during the same release, both a weak version and an interface version definition should be created. The following example shows the addition of a version definition SUNW_1.2 and an interface change SUNW_1.1.1, which are added during the same release cycle. Both interfaces inherit the original interface SUNW_1.1:
$ cat mapfile
SUNW_1.2 { # Release X+1.
global:
foo3;
} SUNW_1.1;
SUNW_1.1.1 { } SUNW_1.1; # Release X+1.
SUNW_1.1 { # Release X.
global:
foo2;
foo1;
local:
The comments for the SUNW_1.1 and SUNW_1.1.1 version definitions indicate that they have both been applied to the same release.
