Occasionally, symbols offered by a vendor's interface become absorbed into a new industry standard. When creating a new standard interface, it is important to maintain the original interface definitions provided by the shared object. To accomplish this it is necessary to create intermediate version definitions on which the new standard, and original interface definitions, can be built.
The following mapfile example shows the addition of a new industry standard interface STAND.1. This interface contains the new symbol foo4 and the existing symbols foo3 and foo1, which were originally offered through the interfaces SUNW_1.2 and SUNW_1.1 respectively:
$ cat mapfile
STAND.1 { # Release X+2.
global:
foo4;
} STAND.0.1 STAND.0.2;
SUNW_1.2 { # Release X+1.
global:
SUNW_1.2;
} STAND.0.1 SUNW_1.1;
SUNW_1.1.1 { } SUNW_1.1; # Release X+1.
SUNW_1.1 { # Release X.
global:
foo2;
local:
} STAND.0.2;
# Subversion - providing for
STAND.0.1 { # SUNW_1.2 and STAND.1 interfaces.
global:
foo3;
STAND.0.2 { # SUNW_1.1 and STAND.1 interfaces.
global:
foo1;
Here the symbols foo3 and foo1 are pulled into their own intermediate interface definitions which are used to build the original and new interface definitions.
The new definition of the SUNW_1.2 interface has referenced its own version definition symbol. Without this reference, the SUNW_1.2 interface would have contained no immediate symbol references and hence would be categorized as a weak version definition.
When migrating symbol definitions to a standards interface, the requirement is that any original interface definitions continue to represent the same symbol list. This requirement can be validated using pvs(1). The following example shows the symbol list of the SUNW_1.2 interface as it existed in the software release X+1:
$ pvs -ds -N SUNW_1.2 libfoo.so.1
SUNW_1.2:
foo3;
SUNW_1.1:
foo2;
foo1;
Although the introduction of the new standards interface in software release X+2 has changed the interface version definitions available, the list of symbols provided by each of the original interfaces remains constant. The following example shows that interface SUNW_1.2 still provides symbols foo1, foo2 and foo3:
SUNW_1.2:
STAND.0.1:
foo3;
SUNW_1.1:
foo2;
STAND.0.2:
foo1;
It is possible that an application might only reference one of the new subversions, in which case any attempt to run the application on a previous release will result in a runtime versioning error (see "Binding to a Version Definition").
In this case an applications version binding can be promoted by directly referencing an existing version name (see "Binding to Additional Version Definitions").
For example, if an application only references the symbol foo1 from the shared object libfoo.so.1, then its version reference will be to STAND.0.2. To allow this application to be run on previous releases, the version binding can be promoted to SUNW_1.1 using a version control mapfile directive:
$ cat prog.c
extern void foo1();
main()
foo1();
$ cc -o prog prog.c -L. -R. -lfoo
$ pvs -r prog
libfoo.so.1 (STAND.0.2);
$ cat mapfile
libfoo.so - SUNW_1.1 $ADDVERS=SUNW_1.1;
$ cc -M mapfile -o prog prog.c -L. -R. -lfoo
$ pvs -r prog
libfoo.so.1 (SUNW_1.1);
In practice, it is rarely necessary to promote a version binding in this manner, as the introduction of new standards binary interfaces is rare, and most applications reference many symbols from an interface family.
