To be able to inspect and manipulate a target process, the rtld-debugger interface employs an exported interface, an imported interface, and agents for communicating between these interfaces.
The controlling process is linked with the rtld-debugger interface provided by librtld_db.so.1, and makes requests of the interface exported from this library. This interface is defined in /usr/include/rtld_db.h. In turn, librtld_db.so.1 makes requests of the interface imported from the controlling process. This interaction allows the rtld-debugger interface to:
Look up symbols in a target process
Read and write memory in the target process
The imported interface consists of a number of proc_service routines (which are described in "Debugger Import Interface"), which most debuggers already employ to analyze processes.
The rtld-debugger interface assumes that the process being analyzed is stopped when requests are made of the rtld-debugger interface. If this is not the case, data structures within the runtime linker of the target process might not be in a consistent state for examination.
The flow of information between librtld_db.so.1, the controlling process (debugger) and the target process (dynamic executable) is diagrammed below:
The rtld-debugger interface is dependent upon the proc_service interface (/usr/include/proc_service.h) which is considered experimental. The rtld-debugger interface might have to track changes in the proc_service interface as it evolves.
A sample implementation of a controlling process that uses the rtld-debugger interface is provided in the SUNWosdem package under /usr/demo/librtld_db. This debugger, rdb, provides an example of using the proc_service imported interface, and shows the required calling sequence for all librtld_db.so.1 exported interfaces. The following sections describe the rtld-debugger interfaces, and more detailed information can be obtained by examining the sample debugger.
