Linker and Libraries Guide
Debugger Interface Agents
An agent provides an opaque handle that can describe internal interface structures, and provides a mechanism of communication between the exported and imported interfaces. As the rtld-debugger interface is intended to be used by a debugger which can manipulate several processes at the same time, these agents are used to identify the process.
struct ps_prochandle;
An opaque structure created by the controlling process to identify the target process which is passed between the exported and imported interface.
struct rd_agent;
struct rd_agent
An opaque structure created by the rtld-debugger interface identifying the target process which is passed between the exported and imported interface.
