Contributions from input files usually appear in the output file in the order of their contribution. An exception occurs when processing tentative symbols and their associated storage. These symbols are not fully defined until their resolution is complete. If the resolution occurs as a result of encountering a defined symbol from a relocatable object, then the order of appearance is that which would have occurred for the definition.
If it is desirable to control the ordering of a group of symbols, then any tentative definition should be redefined to a zero-initialized data item. For example, the following tentative definitions result in a reordering of the data items within the output file, compared to the original order described in the source file foo.c:
$ cat foo.c char A_array[0x10]; char B_array[0x20]; char C_array[0x30]; $ cc -o prog main.c foo.c $ nm -vx prog | grep array [32] |0x00020754|0x00000010|OBJT |GLOB |0x0 |15 |A_array [34] |0x00020764|0x00000030|OBJT |GLOB |0x0 |15 |C_array [42] |0x00020794|0x00000020|OBJT |GLOB |0x0 |15 |B_array |
By defining these symbols as initialized data items, the relative ordering of these symbols within the input file is carried over to the output file:
$ cat foo.c
char A_array[0x10] = { 0 };
char B_array[0x20] = { 0 };
char C_array[0x30] = { 0 };
[32] |0x000206bc|0x00000010|OBJT |GLOB |0x0 |12 |A_array
[42] |0x000206cc|0x00000020|OBJT |GLOB |0x0 |12 |B_array
[34] |0x000206ec|0x00000030|OBJT |GLOB |0x0 |12 |C_array
