After all input files have been read and all symbol resolution is complete, the link-editor searches the internal symbol table for any symbol references that have not been bound to symbol definitions. These symbol references are referred to as undefined symbols. The effect of these undefined symbols on the link-edit process can vary according to the type of output file being generated, and possibly the type of symbol.
When the link-editor is generating an executable output file, the link-editor's default behavior is to terminate the link-edit with an appropriate error message should any symbols remain undefined. A symbol remains undefined when a symbol reference in a relocatable object is never matched to a symbol definition:
$ cat main.c
extern int foo();
main()
return (foo());
$ cc -o prog main.c
Undefined first referenced
symbol in file
foo main.o
ld: fatal: Symbol referencing errors. No output written to prog
In a similar manner, a symbol reference within a shared object that is never matched to a symbol definition when the shared object is being used to build a dynamic executable, will also result in an undefined symbol:
$ cat foo.c
extern int bar;
foo()
return (bar);
$ cc -o libfoo.so -G -K pic foo.c
$ cc -o prog main.c -L. -lfoo
symbol in file
bar ./libfoo.so
If you want to allow undefined symbols, as in cases like the previous example, then the default fatal error condition can be suppressed by using the link-editor's -z nodefs option.
Take care when using the -z nodefs option. If an unavailable symbol reference is required during the execution of a process, a fatal runtime relocation error will occur. Although this error can be detected during the initial execution and testing of an application, more complex execution paths can result in this error condition taking much longer to detect, which can be time consuming and costly.
Symbols can also remain undefined when a symbol reference in a relocatable object is bound to a symbol definition in an implicitly defined shared object. For example, continuing with the files main.c and foo.c used in the previous example:
$ cat bar.c
int bar = 1;
$ cc -o libbar.so -R. -G -K pic bar.c -L. -lfoo
$ ldd libbar.so
libfoo.so => ./libfoo.so
$ cc -o prog main.c -L. -lbar
symbol in file
foo main.o (symbol belongs to implicit \
dependency ./libfoo.so)
Here prog is being built with an explicit reference to libbar.so, and because libbar.so has a dependency on libfoo.so, an implicit reference to libfoo.so from prog is established.
Because main.c made a specific reference to the interface provided by libfoo.so, then prog really has a dependency on libfoo.so. However, only explicit shared object dependencies are recorded in the output file being generated. Thus, prog will fail to run if a new version of libbar.so is developed that no longer has a dependency on libfoo.so.
For this reason, bindings of this type are deemed fatal, and the implicit reference must be made explicit by referencing the library directly during the link-edit of prog (the required reference is hinted at in the fatal error message shown in this example).
The Sun C compiler provides the -xarch=v9 option for compiling 64-bit SPARCV9 objects. The linker has no explicit option telling it to perform a 64-bit link-edit; rather it examines the first object that it is given on the command line and uses its ELF type to determine how to proceed.
When the link-editor is generating a shared object, it will by default allow undefined symbols to remain at the end of the link-edit. This allows the shared object to import symbols from either relocatable objects or other shared objects when it is used to build a dynamic executable. The link-editor's -z defs option can be used to force a fatal error if any undefined symbols remain.
In general, a self-contained shared object, in which all references to external symbols are satisfied by named dependencies, provides maximum flexibility. In this case the shared object can be employed by many users, without those users having to determine and establish dependencies to satisfy the shared objects requirements.
Weak symbol references that are not bound during a link-edit do not result in a fatal error condition, no matter what output file type is being generated.
If a static executable is being generated, the symbol is converted to an absolute symbol and assigned a value of zero.
If a dynamic executable or shared object is being produced, the symbol will be left as an undefined weak reference. During process execution, the runtime linker searches for this symbol, and if it does not find a match, binds the reference to an address of zero instead of generating a fatal runtime relocation error.
Historically, these undefined weak referenced symbols have been employed as a mechanism to test for the existence of functionality. For example, the following C code fragment might have been used in the shared object libfoo.so.1:
#pragma weak foo
extern void foo(char *);
void
bar(char * path)
void (* fptr)();
if ((fptr = foo) != 0)
(* fptr)(path);
When an application is built that references libfoo.so.1, the link-edit will complete successfully regardless of whether a definition for the symbol foo is found. If, during execution of the application, the function address tests nonzero, the function is called. However, if the symbol definition is not found, the function address tests zero, and so is not called.
However, compilation systems view this address comparison technique as having undefined semantics, which can result in the test statement being removed under optimization. In addition, the runtime symbol binding mechanism places other restrictions on the use of this technique, which prevents a consistent model from being available for all dynamic objects.
Undefined weak references in this manner are discouraged; instead, use dlsym(3X) with the RTLD_DEFAULT flag as a means of testing for a symbols existence (see "Testing for Functionality").
