Symbol resolution runs the entire spectrum, from simple and intuitive to complex and perplexing. Resolutions can be carried out silently by the link-editor, be accompanied by warning diagnostics, or result in a fatal error condition.
The resolution of two symbols depends on the symbols' attributes, the type of file providing the symbol, and the type of file being generated. For a complete description of symbol attributes, see "Symbol Table". For the following discussions, however, it is worth identifying three basic symbol types:
These symbols have been referenced in a file but have not been assigned a storage address.
These symbols have been created within a file but have not yet been sized or allocated in storage. They appear as uninitialized C symbols, or FORTRAN COMMON blocks within the file.
These symbols have been created and assigned storage addresses and space within the file.
In its simplest form, symbol resolution involves the use of a precedence relationship that has defined symbols dominating tentative symbols, which in turn dominate undefined symbols.
The following C code example shows how these symbol types can be generated (undefined symbols are prefixed with u_, tentative symbols are prefixed with t_, and defined symbols are prefixed with d_):
$ cat main.c
extern int u_bar;
extern int u_foo();
int t_bar;
int d_bar = 1;
d_foo()
return (u_foo(u_bar, t_bar, d_bar));
$ cc -o main.o -c main.c
$ nm -x main.o
[Index] Value Size Type Bind Other Shndx Name
[8] |0x00000000|0x00000000|NOTY |GLOB |0x0 |UNDEF |u_foo
[9] |0x00000000|0x00000040|FUNC |GLOB |0x0 |2 |d_foo
[10] |0x00000004|0x00000004|OBJT |GLOB |0x0 |COMMON |t_bar
[11] |0x00000000|0x00000000|NOTY |GLOB |0x0 |UNDEF |u_bar
[12] |0x00000000|0x00000004|OBJT |GLOB |0x0 |3 |d_bar
These symbol resolutions are by far the most common, and result when two symbols with similar characteristics are detected and one symbol takes precedence over the other. This symbol resolution is carried out silently by the link-editor. For example, for symbols with the same binding, a reference to an undefined symbol from one file is bound to, or satisfied by, a defined or tentative symbol definition from another file. Or, a tentative symbol definition from one file is bound to a defined symbol definition from another file.
Symbols that undergo resolution can have either a global or weak binding. Weak bindings have less precedence than global binding, so symbols with different bindings are resolved according to a slight alteration of the basic rules. But first, it is worth introducing how weak symbols can be produced.
Weak symbols can be defined individually or as aliases to global symbols using a pragma definition:
$ cat main.c
#pragma weak bar
#pragma weak foo = _foo
int bar = 1;
_foo()
return (bar);
$ nm -x main.o
[7] |0x00000000|0x00000004|OBJT |WEAK |0x0 |3 |bar
[8] |0x00000000|0x00000028|FUNC |WEAK |0x0 |2 |foo
[9] |0x00000000|0x00000028|FUNC |GLOB |0x0 |2 |_foo
Notice that the weak alias foo is assigned the same attributes as the global symbol _foo. This relationship is maintained by the link-editor and results in the symbols being assigned the same value in the output image. In symbol resolution, weak defined symbols are silently overridden by any global definition of the same name.
Another form of simple symbol resolution occurs between relocatable objects and shared objects, or between multiple shared objects, and is termed interposition. In these cases, a symbol that is multiply defined, the relocatable object, or the first definition between multiple shared objects, is silently taken by the link-editor. The relocatable object's definition, or the first shared object's definition, is said to interpose on all other definitions. This interposition can be used to override the functionality provided by one shared object, by a dynamic executable or another shared object.
The combination of weak symbols and interposition provides a very useful programming technique. For example, the standard C library provides several services that you are allowed to redefine. However, ANSI C defines a set of standard services that must be present on the system and cannot be replaced in a strictly conforming program.
The function fread(3S), for example, is an ANSI C library function, whereas the system function read(2) is not. A conforming ANSI C program must be able to redefine read(2) and still use fread(3S) in a predictable way.
The problem here is that read(2) underlies the fread(3S) implementation in the standard C library, therefore it would seem that a program that redefines read(2) might confuse the fread(3S) implementation. To guard against this, ANSI C states that an implementation cannot use a name that is not reserved for it, and by using the pragma directive shown below:
#pragma weak read = _read |
you can define just such a reserved name, and from it generate an alias for the function read(2). Thus, you can quite freely define your own read() function without compromising the fread(3S) implementation, which in turn is implemented to use the _read() function.
The link-editor will not complain of your redefinition of read(), either when linking against the shared object or archive version of the standard C library. In the former case, interposition takes its course, whereas in the latter case, the fact that the C library's definition of read(2) is weak allows it to be quietly overridden.
By using the link-editor's -m option, a list of all interposed symbol references, along with section load address information, is written to the standard output.
Complex resolutions occur when two symbols of the same name are found with differing attributes. In these cases the link-editor selects the most appropriate symbol and generates a warning message indicating the symbol, the attributes that conflict, and the identity of the file from which the symbol definition is taken. For example:
$ cat foo.c
int array[1];
$ cat bar.c
int array[2] = { 1, 2 };
$ cc -dn -r -o temp.o foo.c bar.c
ld: warning: symbol `array' has differing sizes:
(file foo.o value=0x4; file bar.o value=0x8);
bar.o definition taken
Here, two files with a definition of the data item array have different size requirements. A similar diagnostic is produced if the symbols' alignment requirements differ. In both of these cases, the diagnostic can be suppressed by using the link-editor's -t option.
Another form of attribute difference is the symbol's type. For example:
$ cat foo.c
bar()
return (0);
$ cc -o libfoo.so -G -K pic foo.c
$ cat main.c
int bar = 1;
main()
return (bar);
$ cc -o main main.c -L. -lfoo
ld: warning: symbol `bar' has differing types:
(file main.o type=OBJT; file ./libfoo.so type=FUNC);
main.o definition taken
Here the symbol bar() has been defined as both a data item and a function.
types in this context are the symbol types that can be expressed in ELF. They are not related to the data types as employed by the programming language, except in the crudest fashion.
In cases like this, the relocatable object definition is taken when the resolution occurs between a relocatable object and a shared object, or, the first definition is taken when the resolution occurs between two shared objects. When such resolutions occur between symbols of different bindings (weak or global), a warning is also produced.
Inconsistencies between symbol types are not suppressed by the link-editor's -t option.
Symbol conflicts that cannot be resolved result in a fatal error condition. In this case, an appropriate error message is provided indicating the symbol name together with the names of the files that provided the symbols, and no output file is generated. Although the fatal condition is sufficient to terminate the link-edit, all input file processing is first completed. In this manner all fatal resolution errors can be identified.
The most common fatal error condition exists when two relocatable objects both define symbols of the same name, and neither symbol is a weak definition:
$ cat foo.c
int bar = 1;
$ cat bar.c
bar()
return (0);
ld: fatal: symbol `bar' is multiply defined:
(file foo.o and file bar.o);
ld: fatal: File processing errors. No output written to int.o
Here foo.c and bar.c have conflicting definitions for the symbol bar. Because the link-editor cannot determine which should dominate, it usually gives up. However, the link-editor's -z muldefs option can be used to suppress this error condition, and allow the first symbol definition to be taken.
