The mechanism of recording an soname within a shared object is essential if the shared object is ever processed from an archive library.
An archive can be built from one or more shared objects and then used to generate a dynamic executable or shared object. Shared objects can be extracted from the archive to satisfy the requirements of the link-edit (see "Archive Processing" for more details on the criteria for archive extraction). However, unlike the processing of relocatable objects, which are concatenated to the output file being created, any shared objects extracted from the archive will be recorded as dependencies.
The name of an archive member is constructed by the link-editor and is a concatenation of the archive name and the object within the archive. For example:
$ cc -o libfoo.so.1 -G -K pic foo.c $ ar -r libfoo.a libfoo.so.1 $ cc -o main main.o libfoo.a $ dump -Lv main | grep NEEDED [1] NEEDED libfoo.a(libfoo.so.1) |
As it is highly unlikely that a file with this concatenated name will exist at runtime, providing an soname within the shared object is the only means of generating a meaningful runtime filename for the dependency.
The runtime linker does not extract objects from archives. Therefore, in the above example it will be necessary for the required shared object dependencies to be extracted from the archive and made available to the runtime environment.
