When shared objects are used to build a dynamic executable or another shared object, the link-editor performs several consistency checks to ensure that any dependency names that will be recorded in the output file are unique.
Conflicts in dependency names can occur if two shared objects used as input files to a link-edit both contain the same soname. For example:
$ cc -o libfoo.so -G -K pic -h libsame.so.1 foo.c
$ cc -o libbar.so -G -K pic -h libsame.so.1 bar.c
$ cc -o prog main.o -L. -lfoo -lbar
ld: fatal: file ./libbar.so: recording name `libsame.so.1' \
matches that provided by file ./libfoo.so
ld: fatal: File processing errors. No output written to prog
A similar error condition will occur if the filename of a shared object that does not have a recorded soname matches the soname of another shared object used during the same link-edit.
If the runtime name of a shared object being generated matches one of its dependencies, the link-editor will also report a name conflict. For example:
$ cc -o libbar.so -G -K pic -h libsame.so.1 bar.c -L. -lfoo
ld: fatal: file ./libfoo.so: recording name `libsame.so.1' \
matches that supplied with -h option
ld: fatal: File processing errors. No output written to libbar.so
