The previous examples have shown how new version definitions added to an object have inherited any existing version definitions. It is also possible to create version definitions that are unique and independent. In the following example, two new files, bar1.c and bar2.c, are added to the object libfoo.so.1. These files contribute two new symbols, bar1 and bar2, respectively:
$ cat bar1.c
extern void foo1();
void bar1()
foo1();
$ cat bar2.c
extern void foo2();
void bar2()
foo2();
These two symbols are intended to define two new public interfaces. Neither of these new interfaces are related to each other; however, each expresses a dependency on the original SUNW_1.2 interface.
The following mapfile definition creates this required association:
$ cat mapfile
SUNW_1.1 { # Release X
global:
foo1;
local:
SUNW_1.2 { # Release X+1
global:
foo2;
} SUNW_1.1;
SUNW_1.2.1 { } SUNW_1.2; # Release X+2
SUNW_1.3a { # Release X+3
global:
bar1;
} SUNW_1.2;
SUNW_1.3b { # Release X+3
global:
bar2;
} SUNW_1.2;
Again, the version definitions created in libfoo.so.1 using this mapfile, and their related dependencies, can be inspected using pvs(1):
$ cc -o libfoo.so.1 -M mapfile -G foo.o bar.o data.o
$ pvs -dv libfoo.so.1
libfoo.so.1;
SUNW_1.1;
SUNW_1.2: {SUNW_1.1};
SUNW_1.2.1 [WEAK]: {SUNW_1.2};
SUNW_1.3a: {SUNW_1.2};
SUNW_1.3b: {SUNW_1.2};
The following sections explore how these version definition recordings can be used to verify runtime binding requirements and control the binding requirements of an object during its creation.
