On x86 architectures, procedure linkage tables reside in shared text, but they use addresses in the private global offset table. The runtime linker determines the destinations' absolute addresses and modifies the global offset table's memory image accordingly. The runtime linker thus redirects the entries without compromising the position-independence and shareability of the program's text. Executable files and shared object files have separate procedure linkage tables.
Table 7-46 x86: Procedure Linkage Table Example
.PLT0: pushl got_plus_4
jmp *got_plus_8
nop; nop
nop; nop
.PLT1: jmp *name1_in_GOT
pushl $offset
jmp .PLT0@PC
.PLT2: jmp *name2_in_GOT
pushl $offset
jmp .PLT0@PC
.PLT0: pushl 4(%ebx)
jmp *8(%ebx)
nop; nop
nop; nop
.PLT1: jmp *name1@GOT(%ebx)
pushl $offset
jmp .PLT0@PC
.PLT2: jmp *name2@GOT(%ebx)
pushl $offset
jmp .PLT0@PC
Following the steps below, the runtime linker and program cooperate to resolve the symbolic references through the procedure linkage table and the global offset table.
When first creating the memory image of the program, the runtime linker sets the second and third entries in the global offset table to special values. The steps below explain these values.
If the procedure linkage table is position-independent, the address of the global offset table must be in %ebx. Each shared object file in the process image has its own procedure linkage table, and control transfers to a procedure linkage table entry only from within the same object file. So, the calling function must set the global offset table base register before it calls the procedure linkage table entry.
For example, the program calls name1, which transfers control to the label .PLT1.
The first instruction jumps to the address in the global offset table entry for name1. Initially, the global offset table holds the address of the following pushl instruction, not the real address of name1.
So, the program pushes a relocation offset (offset) on the stack. The relocation offset is a 32-bit, nonnegative byte offset into the relocation table. The designated relocation entry has the type R_386_JMP_SLOT, and its offset specifies the global offset table entry used in the previous jmp instruction. The relocation entry also contains a symbol table index, which the runtime linker uses to get the referenced symbol, name1.
After pushing the relocation offset, the program jumps to .PLT0, the first entry in the procedure linkage table. The pushl instruction pushes the value of the second global offset table entry (got_plus_4 or 4(%ebx)) on the stack, giving the runtime linker one word of identifying information. The program then jumps to the address in the third global offset table entry (got_plus_8 or 8(%ebx)), to jump to the runtime linker.
The runtime linker unwinds the stack, checks the designated relocation entry, gets the symbol's value, stores the actual address of name1 in its global offset entry table, and jumps to the destination.
Subsequent executions of the procedure linkage table entry transfer directly to name1, without calling the runtime linker again. This is because the jmp instruction at .PLT1 jumps to name1 instead of falling through to the pushl instruction.
The LD_BIND_NOW environment variable changes dynamic linking behavior. If its value is non-null, the runtime linker processes R_386_JMP_SLOT relocation entries (procedure linkage table entries) before transferring control to the program. If LD_BIND_NOW is null, the runtime linker evaluates linkage table entries on the first execution of each table entry.
