The rtld-debugger interface offers the ability to help skip over procedure linkage table entries (refer to "Procedure Linkage Table (Processor-Specific)"). When a controlling process, such as a debugger, is asked to step into a function for the first time, they often wish to skip the actual procedure linkage table processing, as this results in control being passed to the runtime linker to search for the function definition.
The following interface allows a controlling process to step over the runtime linker's procedure linkage table processing. It is assumed that the controlling process can determine when a procedure linkage table entry is encountered, based on external information provided in the ELF file.
Once a target process has stepped into a procedure linkage table entry, it calls the following interface:
rd_err_e rd_plt_resolution(rd_agent_t * rdap, paddr_t pc,
lwpid_t lwpid, paddr_t plt_base, rd_plt_info_t * rpi);
This function returns the resolution state of the current procedure linkage table entry and information on how to skip it.
pc represents the first instruction of the procedure linkage table entry. lwpid privides the lwp identifier and plt_base provides the base address of the procedure linkage table. These three variables provide information sufficient for various architectures to process the procedure linkage table.
rpi provides detailed information regarding the procedure linkage table entry as defined in the following data structure (defined in rtld_db.h):
typedef enum {
RD_RESOLVE_NONE,
RD_RESOLVE_STEP,
RD_RESOLVE_TARGET,
RD_RESOLVE_TARGET_STEP
} rd_skip_e;
typedef struct rd_plt_info {
rd_skip_e pi_skip_method;
long pi_nstep;
psaddr_t pi_target;
} rd_plt_info_t;
The following scenarios are possible from the rd_plt_info_t return values:
This is the first call through this procedure linkage table so it must be resolved by the runtime linker. rd_plt_info_t will contain:
{RD_RESOLVE_TARGET_STEP, M, <BREAK>}
The controlling process sets a break-point at BREAK and continues the target process. When the break-point is reached, the procedure linkage table entry processing has finished, and the controlling process can step M instructions to the destination function.
This is the Nth time through this procedure linkage table. rd_plt_info_t will contain:
{RD_RESOLVE_STEP, M, 0}
The procedure linkage table entry has already been resolved and the controlling process can step M instructions to the destination function.
Future implementations might employ RD_RESOLVE_TARGET as a means of setting a break point directly in the target function; however, this capability is not yet available in this version of the rtld-debugger interface.
