The default behavior of the runtime linker relies on the operating system to load dynamic objects where they can be most efficiently referenced. Some controlling processes benefit from the existence of padding around the objects loaded into memory of the target process. This interface allows a controlling process to request this padding.
rd_err_e rd_objpad_enable(struct rd_agent * rdap, size_t padsize); |
This function enables or disables the padding of any subsequently loaded objects with the target process. Padding occurs on both sides of the loaded object.
padsize specifies the size of the padding, in bytes, to be preserved both before and after any objects loaded into memory. This padding is reserved as a memory mapping using mmap(2) with PROT_NONE permissions and the MAP_NORESERVE flag. Effectively the runtime linker reserves areas of the virtual address space of the target process adjacent to any mapped objects. These areas can later be utilized by the controlling process.
A padsize of 0 disables any object padding for later objects.
Reservations obtained using mmap(2) from /dev/zero with MAP_NORESERVE can be reported using the proc(1) facilities and by referring to the link-map information provided in rd_loadobj_t.
