Sometimes a vendor or system builder needs to mark an object file with special information that other programs will check for conformance, compatibility, and so forth. Sections of type SHT_NOTE and program header elements of type PT_NOTE can be used for this purpose.
The note information in sections and program header elements holds any number of entries, each of which is an array of 4-byte words in the format of the target processor. Labels are shown on Figure 7-5 to help explain note information organization, but they are not part of the specification.
The first namesz bytes in name contain a null-terminated character representation of the entry's owner or originator. There is no formal mechanism for avoiding name conflicts. By convention, vendors use their own name, such as "XYZ Computer Company," as the identifier. If no name is present, namesz contains 0. Padding is present, if necessary, to ensure 4-byte alignment for the descriptor. Such padding is not included in namesz.
The first descsz bytes in desc hold the note descriptor. If no descriptor is present, descsz contains 0. Padding is present, if necessary, to ensure 4-byte alignment for the next note entry. Such padding is not included in descsz.
This word gives the interpretation of the descriptor. Each originator controls its own types; multiple interpretations of a single type value can exist. Thus, a program must recognize both the name and the type to understand a descriptor. Types currently must be nonnegative.
To illustrate, the following note segment holds two entries.
The system reserves note information with no name (namesz==0) and with a zero-length name (name[0]=='\0') but currently defines no types. All other names must have at least one non-null character.
