Objects created by the link-editor can contain two types of versioning information:
Version definitions provide associations of global symbols and are implemented using sections of type SHT_SUNW_verdef and SHT_SUNW_versym.
Version dependencies indicate the version definition requirements from other object dependencies and are implemented using sections of type SHT_SUNW_verneed.
The structures that form these sections are defined in sys/link.h. Sections that contain versioning information are named .SUNW_version.
This section is defined by the type SHT_SUNW_verdef. If this section exists, a SHT_SUNW_versym section must also exist. Using these two structures, an association of symbols-to-version definitions is maintained within the file (see "Creating a Version Definition" for more details). Elements of this section have the following structure:
typedef struct { Elf32_Half vd_version; Elf32_Half vd_flags; Elf32_Half vd_ndx; Elf32_Half vd_cnt; Elf32_Word vd_hash; Elf32_Word vd_aux; Elf32_Word vd_next; } Elf32_Verdef; typedef struct { Elf32_Word vda_name; Elf32_Word vda_next; } Elf32_Verdaux; typedef struct { Elf64_Half vd_version; Elf64_Half vd_flags; Elf64_Half vd_ndx; Elf64_Half vd_cnt; Elf64_Word vd_hash; Elf64_Word vd_aux; Elf64_Word vd_next; } Elf64_Verdef; typedef struct { Elf64_Word vda_name; Elf64_Word vda_next; } Elf64_Verdaux; |
This member identifies the version of the structure itself.
Name |
Value |
Meaning |
VER_DEF_NONE |
0 |
Invalid version |
VER_DEF_CURRENT |
>=1 |
Current version |
The value 1 signifies the original section format; extensions will create new versions with higher numbers. The value of VER_DEF_CURRENT changes as necessary to reflect the current version number.
This member holds version definition-specific information.
Name |
Value |
Meaning |
VER_FLG_BASE |
0x1 |
Version definition of the file itself |
VER_FLG_WEAK |
0x2 |
Weak version identifier |
The base version definition is always present when version definitions, or symbol auto-reduction, has been applied to the file. The base version provides a default version for the files reserved symbols (see "Generating the Output Image"). A weak version definition has no symbols associated with it (see "Creating a Weak Version Definition" for more details).
This member holds the version index. Each version definition has a unique index that is used to associate SHT_SUNW_versym entries to the appropriate version definition.
This member indicates the number of elements in the Elf32_Verdaux array.
This member holds the hash value of the version definition name (this value is generated using the same hashing function described in "Hash Table").
This member holds the byte offset, from the start of this Elf32_Verdef entry, to the Elf32_Verdaux array of version definition names. The first element of the array must exist and points to the version definition string this structure defines. Additional elements can be present, the number being indicated by the vd_cnt value. These elements represent the dependencies of this version definition. Each of these dependencies will have its own version definition structure.
This member holds the byte offset, from the start of this Elf32_Verdef structure, to the next Elf32_Verdef entry.
This member holds a string table offset to a null-terminated string, giving the name of the version definition.
This member holds the byte offset, from the start of this Elf32_Verdaux entry, to the next Elf32_Verdaux entry.
This section is defined by the type SHT_SUNW_versym, and consists of an array of elements having the following structure:
typedef Elf32_Half Elf32_Versym; typedef Elf64_Half Elf64_Versym; |
The number of elements of the array must equal the number of symbol table entries contained in the associated symbol table (determined by the sections sh_link value). Each element of the array contains a single index that can have the following values:
Table 7-31 Version Dependency Indexes
Name |
Value |
Meaning |
VER_NDX_LOCAL |
0 |
Symbol has local scope |
VER_NDX_GLOBAL |
1 |
Symbol has global scope (assigned to base version definition) |
>1 |
Symbol has global scope (assigned to user-defined version definition) |
Any index values greater than VER_NDX_GLOBAL must correspond to the vd_ndx value of an entry in the SHT_SUNW_verdef section. If no index values greater than VER_NDX_GLOBAL exist, then no SHT_SUNW_verdef section need be present.
This section is defined by the type SHT_SUNW_verneed. This section compliments the dynamic dependency requirements of the file by indicating the version definitions required from these dependencies. Only if a dependency contains version definitions will a recording be made in this section. Elements of this section have the following structure:
typedef struct { Elf32_Half vn_version; Elf32_Half vn_cnt; Elf32_Word vn_file; Elf32_Word vn_aux; Elf32_Word vn_next; } Elf32_Verneed; typedef struct { Elf32_Word vna_hash; Elf32_Half vna_flags; Elf32_Half vna_other; Elf32_Word vna_name; Elf32_Word vna_next; } Elf32_Vernaux; typedef struct { Elf64_Half vn_version; Elf64_Half vn_cnt; Elf64_Word vn_file; Elf64_Word vn_aux; Elf64_Word vn_next; } Elf64_Verneed; typedef struct { Elf64_Word vna_hash; Elf64_Half vna_flags; Elf64_Half vna_other; Elf64_Word vna_name; Elf64_Word vna_next; } Elf64_Vernaux; |
Name |
Value |
Meaning |
VER_NEED_NONE |
0 |
Invalid version |
VER_NEED_CURRENT |
>=1 |
Current version |
The value 1 signifies the original section format; extensions will create new versions with higher numbers. The value of VER_NEED_CURRENT changes as necessary to reflect the current version number.
This member indicates the number of elements in the Elf32_Vernaux array.
This member holds a string table offset to a null-terminated string, giving the filename having a version dependency. This name will match one of the .dynamic dependencies (refer to "Dynamic Section") found in the file.
This member holds the byte offset, from the start of this Elf32_Verneed entry, to the Elf32_Vernaux array of version definitions required from the associated file dependency. There must exist at least one version dependency. Additional version dependencies can be present, the number being indicated by the vn_cnt value.
This member holds the byte offset, from the start of this Elf32_Verneed entry, to the next Elf32_Verneed entry.
This member holds the hash value of the version dependency name (this value is generated using the same hashing function described in "Hash Table").
This member holds version dependency specific information.
Name |
Value |
Meaning |
VER_FLG_WEAK |
0x2 |
A weak version dependency indicates an original binding to a weak version definition. See "Creating a Version Definition" for more details.
This member is presently unused.
This member holds a string table offset to a null-terminated string, giving the name of the version dependency.
This member holds the byte offset, from the start of this Elf32_Vernaux entry, to the next Elf32_Vernaux entry.
