As mentioned above, ELF provides an object file framework to support multiple processors, multiple data encoding, and multiple classes of machines. To support this object file family, the initial bytes of the file specify how to interpret the file, independent of the processor on which the inquiry is made and independent of the file's remaining contents.
The initial bytes of an ELF header (and an object file) correspond to the e_ident member.
Table 7-7 e_ident[ ] Identification Index|
Name |
Value |
Purpose |
EI_MAG0 |
0 |
File identification |
EI_MAG1 |
1 |
EI_MAG2 |
2 |
EI_MAG3 |
3 |
EI_CLASS |
4 |
File class |
EI_DATA |
5 |
Data encoding |
EI_VERSION |
6 |
File version |
EI_PAD |
7 |
Start of padding bytes |
EI_NIDENT |
16 |
Size of e_ident[] |
These indexes access bytes that hold the following values:
A file's first 4 bytes hold a magic number, identifying the file as an ELF object file.
Name |
Value |
Position |
ELFMAG0 |
0x7f |
e_ident[EI_MAG0] |
ELFMAG1 |
'E' |
e_ident[EI_MAG1] |
ELFMAG2 |
'L' |
e_ident[EI_MAG2] |
ELFMAG3 |
'F' |
e_ident[EI_MAG3] |
The next byte, e_ident[EI_CLASS], identifies the file's class, or capacity.
Name |
Value |
Meaning |
ELFCLASSNONE |
0 |
Invalid class |
ELFCLASS32 |
1 |
32-bit objects |
ELFCLASS64 |
2 |
64-bit objects |
The file format is designed to be portable among machines of various sizes, without imposing the sizes of the largest machine on the smallest. Class ELFCLASS32 supports machines with files and virtual address spaces up to 4 gigabytes; it uses the basic types defined above.
Class ELFCLASS64 is reserved for 64-bit architectures such as SPARCV9.
Byte e_ident[EI_DATA] specifies the data encoding of the processor-specific data in the object file. The following encodings are currently defined.
Name |
Value |
Meaning |
ELFDATANONE |
0 |
Invalid data encoding |
ELFDATA2LSB |
1 |
See Figure 7-2. |
ELFDATA2MSB |
2 |
See Figure 7-3. |
More information on these encodings appears below. Other values are reserved and will be assigned to new encodings as necessary.
Byte e_ident[EI_VERSION] specifies the ELF header version number. Currently, this value must be EV_CURRENT, as explained in Table 7-5 for e_version.
This value marks the beginning of the unused bytes in e_ident. These bytes are reserved and set to zero; programs that read object files should ignore them. The value of EI_PAD will change in the future if currently unused bytes are given meanings.
A file's data encoding specifies how to interpret the basic objects in a file. As described above, class ELFCLASS32 files use objects that occupy 1, 2, and 4 bytes. Under the defined encodings, objects are represented as shown below. Byte numbers appear in the upper left corners.
Encoding ELFDATA2LSB specifies 2's complement values, with the least significant byte occupying the lowest address.
Encoding ELFDATA2MSB specifies 2's complement values, with the most significant byte occupying the lowest address.
