Some object file control structures can grow, because the ELF header contains their actual sizes. If the object file format changes, a program can encounter control structures that are larger or smaller than expected. Programs might therefore ignore extra information. The treatment of missing information depends on context and will be specified if and when extensions are defined.
The ELF header has the following structure (defined in sys/elf.h):
#define EI_NIDENT 16
typedef struct {
unsigned char e_ident[EI_NIDENT];
Elf32_Half e_type;
Elf32_Half e_machine;
Elf32_Word e_version;
Elf32_Addr e_entry;
Elf32_Off e_phoff;
Elf32_Off e_shoff;
Elf32_Word e_flags;
Elf32_Half e_ehsize;
Elf32_Half e_phentsize;
Elf32_Half e_phnum;
Elf32_Half e_shentsize;
Elf32_Half e_shnum;
Elf32_Half e_shstrndx;
} Elf32_Ehdr;
typedef struct {
Elf64_Half e_type;
Elf64_Half e_machine;
Elf64_Word e_version;
Elf64_Addr e_entry;
Elf64_Off e_phoff;
Elf64_Off e_shoff;
Elf64_Word e_flags;
Elf64_Half e_ehsize;
Elf64_Half e_phentsize;
Elf64_Half e_phnum;
Elf64_Half e_shentsize;
Elf64_Half e_shnum;
Elf64_Half e_shstrndx;
} Elf64_Ehdr;
The initial bytes mark the file as an object file and provide machine-independent data with which to decode and interpret the file's contents. Complete descriptions appear in "ELF Identification".
This member identifies the object file type.
Name |
Value |
Meaning |
ET_NONE |
0 |
No file type |
ET_REL |
1 |
Relocatable file |
ET_EXEC |
2 |
Executable file |
ET_DYN |
3 |
Shared object file |
ET_CORE |
4 |
Core file |
ET_LOPROC |
0xff00 |
Processor-specific |
ET_HIPROC |
0xffff |
Although the core file contents are unspecified, type ET_CORE is reserved to mark the file. Values from ET_LOPROC through ET_HIPROC (inclusive) are reserved for processor-specific semantics. Other values are reserved and will be assigned to new object file types as necessary.
This member's value specifies the required architecture for an individual file.
Name |
Value |
Meaning |
EM_NONE |
0 |
No machine |
EM_M32 |
1 |
AT&T WE 32100 |
EM_SPARC |
2 |
SPARC |
EM_386 |
3 |
Intel 80386 |
EM_68K |
4 |
Motorola 68000 |
EM_88K |
5 |
Motorola 88000 |
EM_486 |
6 |
Intel 80486 |
EM_860 |
7 |
Intel 80860 |
EM_MIPS |
8 |
MIPS RS3000 Big-Endian |
EM_MIPS_RS3_LE |
10 |
MIPS RS3000 Little-Endian |
EM_RS6000 |
11 |
RS6000 |
EM_PA_RISC |
15 |
PA-RISC |
EM_nCUBE |
16 |
nCUBE |
EM_VPP500 |
17 |
Fujitsu VPP500 |
EM_SPARC32PLUS |
18 |
Sun SPARC 32+ |
EM_PPC |
20 |
PowerPC |
EM_SPARCV9 |
43 |
SPARC V9 |
Other values are reserved and will be assigned to new machines as necessary. Processor-specific ELF names use the machine name to distinguish them. For example, the flags mentioned below use the prefix EF_; a flag named WIDGET for the EM_XYZ machine would be called EF_XYZ_WIDGET.
This member identifies the object file version.
Name |
Value |
Meaning |
EV_NONE |
0 |
Invalid version |
EV_CURRENT |
>=1 |
Current version |
The value 1 signifies the original file format; extensions will create new versions with higher numbers. The value of EV_CURRENT changes as necessary to reflect the current version number.
This member gives the virtual address to which the system first transfers control, thus starting the process. If the file has no associated entry point, this member holds zero.
This member holds the program header table's file offset in bytes. If the file has no program header table, this member holds zero.
This member holds the section header table's file offset in bytes. If the file has no section header table, this member holds zero.
This member holds processor-specific flags associated with the file. Flag names take the form EF_machine_flag. This member is presently zero for SPARC and x86.
Table 7-6 ELF Flags for SPARCV9|
Name |
Value |
Meaning |
EF_SPARCV9_MM |
0x3 |
Mask for Memory Model |
EF_SPARCV9_TSO |
0x0 |
Total Store Ordering |
EF_SPARCV9_PSO |
0x1 |
Partial Store Ordering |
EF_SPARCV9_RMO |
0x2 |
Relaxed Memory Ordering |
EF_SPARC_EXT_MASK |
0xffff00 |
Vendor Extension mask |
EF_SPARC_SUN_US1 |
0x000200 |
Sun UltraSPARC 1 Extensions |
EF_SPARC_HAL_R1 |
0x000400 |
HAL R1 Extensions |
EF_SPARC_SUN_US3 |
0x000800 |
Sun UltraSPARC 3 Extensions |
This member holds the ELF header's size in bytes.
This member holds the size in bytes of one entry in the file's program header table; all entries are the same size.
This member holds the number of entries in the program header table. Thus the product of e_phentsize and e_phnum gives the table's size in bytes. If a file has no program header table, e_phnum holds the value zero.
This member holds a section header's size in bytes. A section header is one entry in the section header table; all entries are the same size.
This member holds the number of entries in the section header table. Thus the product of e_shentsize and e_shnum gives the section header table's size in bytes. If a file has no section header table, e_shnum holds the value zero.
This member holds the section header table index of the entry associated with the section name string table. If the file has no section name string table, this member holds the value SHN_UNDEF. See "Sections" and "String Table" for more information.
