Position-independent code cannot, in general, contain absolute virtual addresses. Global offset tables hold absolute addresses in private data, thus making the addresses available without compromising the position-independence and shareability of a program's text. A program references its global offset table using position-independent addressing and extracts absolute values, thus redirecting position-independent references to absolute locations.
Initially, the global offset table holds information as required by its relocation entries (see "Relocation" for more information). After the system creates memory segments for a loadable object file, the runtime linker processes the relocation entries, some of which will be type R_SPARC_GLOB_DAT (for SPARC), or R_386_GLOB_DAT (for x86), referring to the global offset table.
The runtime linker determines the associated symbol values, calculates their absolute addresses, and sets the appropriate memory table entries to the proper values. Although the absolute addresses are unknown when the link-editor builds an object file, the runtime linker knows the addresses of all memory segments and can thus calculate the absolute addresses of the symbols contained therein.
If a program requires direct access to the absolute address of a symbol, that symbol will have a global offset table entry. Because the executable file and shared objects have separate global offset tables, a symbol's address can appear in several tables. The runtime linker processes all the global offset table relocations before giving control to any code in the process image, thus ensuring the absolute addresses are available during execution.
The table's entry zero is reserved to hold the address of the dynamic structure, referenced with the symbol _DYNAMIC. This allows a program, such as the runtime linker, to find its own dynamic structure without having yet processed its relocation entries. This is especially important for the runtime linker, because it must initialize itself without relying on other programs to relocate its memory image.
The system can choose different memory segment addresses for the same shared object in different programs; it can even choose different library addresses for different executions of the same program. Nonetheless, memory segments do not change addresses once the process image is established. As long as a process exists, its memory segments reside at fixed virtual addresses.
A global offset table's format and interpretation are processor-specific. For SPARC and x86 processors, the symbol _GLOBAL_OFFSET_TABLE_ can be used to access the table. For 64-bit code, the symbol type is an array of Elf64_Addr.
extern Elf32_Addr _GLOBAL_OFFSET_TABLE_[]; |
The symbol _GLOBAL_OFFSET_TABLE_ can reside in the middle of the .got section, allowing both negative and nonnegative subscripts into the array of addresses.
