usedisk disk_name [disk_name...] |
usedisk designates one or more disks that you want the Solaris installation program to use when partitioning default is specified (by default, the installation program uses all the operational disks on the system). disk_name must be specified in the form cxtydz or cydz, for example, c0t0d0.
If you specify the usedisk profile keyword in a profile, the Solaris installation program will only use the disks that you specify with the usedisk profile keyword.
You cannot specify the usedisk keyword and the dontuse keyword in the same profile.
