Solaris Advanced Installation Guide
Profile Keyword and Profile Value Descriptions
The following sections describe the profile keywords and profile values that you can use in a profile. Profile keywords and their values are case sensitive.
Table 8-3 provides a quick way to determine which keywords you can use based on your installation scenario. Unless otherwise noted in the profile keyword descriptions, the profile keyword can only be used with the initial installation option.
Table 8-3 Profile Keyword Overview
Installation Scenarios
Profile Keywords
Standalone System (Non-Networked)
Standalone System (Networked) or Server
OS Server
Upgrade
Upgrade with Disk Space Reallocation
backup_media
x
boot_device
x
x
x
client_arch
x
client_root
x
client_swap
x
cluster (adding software groups)
x
x
x
cluster (adding/deleting clusters)
x
x
x
x
x
dontuse
x
x
x
fdisk
x
x
x
filesys (mounting remote filesystems)
x
x
filesys (creating local filesystems)
x
x
x
install_type
x
x
x
x
x
isa_bits
x
x
x
x
x
layout_constraint
x
locale
x
x
x
x
x
num_clients
x
package
x
x
x
x
x
partitioning
x
x
x
root_device
x
x
x
x
x
system_type
x
x
x
usedisk
x
x
x
backup_media Profile Keyword
backup_media type   path
Note -
backup_media must be used only with the upgrade option when disk space reallocation is required.
backup_media defines the media that will be used to back up file systems if space needs to be reallocated during an upgrade because of space problems. If multiple tapes or diskettes are required for the backup, you will be prompted to insert tapes or diskettes during the upgrade.
Valid type Values
Valid path Values
Description
local_tape
/dev/rmt/n
Specifies a local tape drive on the system being upgraded. path must be the character (raw) device path for the tape drive, where n is the number of the tape drive.
local_diskette
/dev/rdisketten
Specifies a local diskette drive on the system being upgraded. path must be the character (raw) device path for the diskette drive, where n is the number of the diskette drive.
Note -
Diskettes used for the backup must be formatted.
local_filesystem
/dev/dsk/cwtxdysz
/file_system
Specifies a local file system on the system being upgraded. You cannot specify a local file system that is being changed by the upgrade. path can be a block device path for a disk slice (tx may not be needed) or the absolute path to a file system mounted by the /etc/vfstab file.
remote_filesystem
host:/file_system
Specifies an NFS file system on a remote system. path must include the name or IP address of the remote system (host) and the absolute path to the NFS file system (file_system). The NFS file system must have read/write access.
remote_systemuser@host:/directory
Specifies a directory on a remote system that can be reached by a remote shell (rsh). The system being upgraded must have access to the remote system through the remote system's .rhosts file. path must include the name of the remote system (host) and the absolute path to the directory (directory). If a user login (user) is not specified, the login will be tried as root.
Examples:
backup_media local_tape /dev/rmt/0
backup_media local_diskette /dev/rdiskette1
backup_media local_filesystem /dev/dsk/c0t3d0s4
backup_media local_filesystem /export
backup_media remote_filesystem system1:/export/temp
backup_media remote_system user1@system1:/export/temp
boot_device Profile Keyword
boot_device  device   eeprom
boot_device designates the device where the installation program will install the root file system and consequently what the system's boot device will be. The eeprom value also enables you to update the system's EEPROM if you change the system's current boot device, so the system can automatically boot from the new boot device (SPARC systems only).
If you don't specify the boot_device keyword in a profile, the following boot_device keyword is specified by default during the installation: boot_device any update.
device - Choose what the boot device will be.
eeprom - Choose if you want to update the system's EEPROM to the specified boot device (SPARC-based systems only). For x86 based systems, you must always specify the preserve value.
Example:
boot_device c0t0d0s2 update
Note -
boot_device must match any filesys keywords that specify the root file system and the root_device keyword (if specified).
client_arch Profile Keyword
client_arch karch_value[karch_value...]
client_arch defines that the OS server will support a different platform group than it uses. If you do not specify client_arch, any diskless client or Solstice AutoClient system that uses the OS server must have the same platform group as the server. You must specify each platform group that you want the OS server to support.
Valid values for karch_value are: sun4d, sun4c, sun4m, sun4u, i86pc. (See Appendix C, Platform Names and Groups for a detailed list of the platform names of various systems.)
Note -
client_arch can be used only when system_type is specified as server.
client_root Profile Keyword
client_root root_size
client_root defines the amount of root space (root_size in Mbytes) to allocate for each client. If you do not specify client_root in a server's profile, the installation software will automatically allocate 15 Mbytes of root space per client. The size of the client root area is used in combination with the num_clients keyword to determine how much space to reserve for the /export/root file system.
Note -
client_root can be used only when system_type is specified as server.
client_swap Profile Keyword
client_swap swap_size
client_swap defines the amount of swap space (swap_size in Mbytes) to allocate for each diskless client. If you do not specify client_swap, 32 Mbytes of swap space is allocated.
Example:
client_swap 64
The example defines that each diskless client will have a swap space of 64 Mbytes.
Note -
client_swap can be used only when system_type is specified as server.
cluster Profile Keyword (Adding Software Groups)
cluster group_name
cluster designates what software group to add to the system. The cluster names for the software groups are:
Software Group
group_name
Core
SUNWCreq
End user system support
SUNWCuser
Developer system support
SUNWCprog
Entire distribution
SUNWCall
Entire distribution plus OEM support (SPARC-based systems only)
SUNWCXall
You can specify only one software group in a profile, and it must be specified before other cluster and package entries. If you do not specify a software group with cluster, the end user software group (SUNWCuser) is installed on the system by default.
cluster Profile Keyword (Adding or Deleting Clusters)
cluster cluster_name [add | delete]
Note -
cluster (adding or deleting clusters) can be used with both the initial installation and upgrade options.
cluster designates whether a cluster should be added or deleted from the software group that will be installed on the system. add or delete indicates whether the cluster should be added or deleted. If you do not specify add or delete, add is set by default.
cluster_name must be in the form SUNWCname. To view detailed information about clusters and their names, start Admintool on an installed system and choose Software from the Browse menu.
For Upgrade:
dontuse Profile Keyword
dontuse disk_name [disk_name...]
dontuse designates one or more disks that you don't want the Solaris installation program to use when partitioning default is specified (by default, the installation program uses all the operational disks on the system). disk_name must be specified in the form cxtydz or cydz, for example, c0t0d0.
Note -
You cannot specify the dontuse keyword and the usedisk keyword in the same profile.
fdisk Profile Keyword
fdisk disk_name  type  size
fdisk defines how the fdisk partitions are set up on an x86-based system, and you can specify fdisk more than once. This is what happens by default with fdisk partitions on x86 --based systems:
disk_name - Choose where the fdisk partition will be created or deleted:
type - Choose what type of fdisk partition will be created or deleted on the specified disk:
The following table shows the integer and hexadecimal numbers for some of the fdisk types:
fdisk Type
DDD
HH
DOSOS12
1
01
PCIXOS
2
02
DOSOS16
4
04
EXTDOS
5
05
DOSHUGE
6
06
DOSDATA
86
56
OTHEROS
98
62
UNIXOS
99
63
size - Choose one of the following:
filesys Profile Keyword (Mounting Remote File Systems)
filesys server:path  server_address  mount_pt_name [mount_options]
This instance of filesys sets up the installed system to automatically mount remote file systems when it boots. You can specify filesys more than once.
Example:
filesys sherlock:/export/home/user2 - /home
server: - The name of the server where the remote file system resides (followed by a colon).
path - The remote file system's mount point name, for example, /usr or /export/home.
server_address - The IP address of the server specified in server:path. If you don't have a name service running on the network, this value can be used to populate the /etc/hosts file with the server's host name and IP address. If you don't want to specify the server's IP address (if you have a name service running on the network), you must specify a minus sign (-).
mount_pt_name - The name of the mount point that the remote file system will be mounted on.
mount_options - One or more mount options (-o option of the mount(1M) command) that are added to the /etc/vfstab entry for the specified mount_pt_name.
Note -
If you need to specify more than one mount option, the mount options must be separated by commas and no spaces. For example: ro,quota
filesys Profile Keyword (Creating Local File Systems)
filesys slice  size  [file_system]  [optional_parameters]
This instance of filesys creates local file systems during the installation. You can specify filesys more than once.
slice - Choose one of the following:
file_system - You can use this optional value when slice is specified as any or cwtxdysz. If file_system is not specified, unnamed is set by default, but then you can't specify the optional_parameters value. Choose one of the following:
optional_parameters - Choose one of the following:
install_type Profile Keyword
install_type initial_install | upgrade
install_type defines whether to perform the initial installation option or upgrade option on the system.
Note -
install_type must be the first profile keyword in every profile.
Note -
Some profile keywords can only be used with the initial_install option, and this also applies to the upgrade option.
isa_bits Profile Keyword
isa_bits 64 | 32
isa_bits determines whether 64-bit or 32-bit Solaris packages are installed. Valid values are 64 and 32. If you do not set this keyword, the installation program installs the default packages. The default for UltraSPARC systems is 64-bit packages. For all other systems, the default is 32-bit packages.
Note -
isa_bits is a new keyword. If you use it, you must also use the latest check script in the Solaris_2.7/Misc/jumpstart_sample directory on the Solaris CD.
layout_constraint Profile Keyword
layout_constraint slice constraint [minimum_size]
Note -
layout constraint can be used only for the upgrade option when disk space reallocation is required.
layout_constraint designates the constraint auto-layout has on a file system if it needs to reallocate space during an upgrade because of space problems.
If you don't specify the layout_constraint keyword, the:
If you specify one or more layout_constraint keywords, the
Even though you can't change the constraint on file systems requiring more space for the upgrade (they must be marked changeable), you can use layout_constraint on those file systems to change their minimum_size values.
Note -
To help auto-layout reallocate space, select more file systems to be changeable or moveable, especially those that reside on the same disks as the file systems that require more space for the upgrade.
slice - This is the file system's disk slice on which to specify the constraint. It must be specified in the form cwtxdysz or cxdysz.
constraint - Choose one the following constraints for the specified file system.
Examples:
layout_constraint c0t3d0s1 changeable 200
layout_constraint c0d0s4 movable
layout_constraint c0t3d1s3 availiable
layout_constraint c0t2d0s1 collapse
locale locale_name Profile Keyword
locale locale_name
Note -
locale can be used with both the initial installation and upgrade options.
locale designates which locale packages should be installed (or added for upgrade) for the specified locale_name. The locale_name values are the same used for the $LANG environment variable. See Appendix E, Locale Values for a list of valid locale values.
Note -
If you have preconfigured a default locale, it is automatically installed. The English language packages are installed by default.
Note -
You can specify a locale keyword for each locale you need to add to a system.
num_clients Profile Keyword
num_clients client_num
When a server is installed, space is allocated for each diskless client's root (/) and swap file systems. num_clients defines the number of diskless clients (client_num) that a server will support. If you do not specify num_clients, five diskless clients are allocated.
Note -
num_clients can be used only when system_type is specified as server.
package Profile Keyword
package package_name [add | delete]
Note -
package can be used with both the initial installation and upgrade options.
package designates whether a package should be added to or deleted from the software group that will be installed on the system. add or delete indicates whether the package should be added or deleted. If you do not specify add | delete, add is set by default.
package_name must be in the form SUNWname. Use the pkginfo -l command or Admintool (choose Software from the Browse menu) on an installed system to view detailed information about packages and their names.
For Upgrade:
partitioning Profile Keyword
partitioning default | existing | explicit
partitioning defines how the disks are divided into slices for file systems during the installation. If you do not specify partitioning, default is set.
default - The Solaris installation program selects the disks and creates the file systems on which to install the specified software, except for any file systems specified by the filesys keyword. rootdisk is selected first; additional disks are used if the specified software does not fit on rootdisk.
existing - The Solaris installation program uses the existing file systems on the system's disks. All file systems except /, /usr, /usr/openwin, /opt, and /var are preserved. The installation program uses the last mount point field from the file system superblock to determine which file system mount point the slice represents.
Note -
When specifying the filesys profile keyword with partitioning existing, size must be existing.
explicit - The Solaris installation program uses the disks and creates the file systems specified by the filesys keywords. If you specify only the root (/) file system with the filesys keyword, all the Solaris software will be installed in the root file system.
Note -
When you use the explicit profile value, you must use the filesys profile keyword to specify which disks to use and what file systems to create.
root_device Profile Keyword
root_device slice
Note -
root_device can be used with both the initial installation and upgrade options.
root_device designates the system's root disk. See "How the System's Root Disk Is Determined" for more information.
For Upgrade:
root_device designates the root file system (and the file systems mounted by its /etc/vfstab file) to be upgraded. You must specify root_device if more than one root file system can be upgraded on a system. slice must be specified in the form cwtxdysz or cxdysz.
Example:
root_device c0t0d0s2
Note -
If you specify root_device on a system with only one disk, the root_device and the disk must match. Also, any filesys keywords that specify the root file system must match root_device.
system_type Profile Keyword
system_type standalone | server
system_type defines the type of system being installed. If you do not specify system_type in a profile, standalone is set by default.
usedisk Profile Keyword
usedisk disk_name [disk_name...]
usedisk designates one or more disks that you want the Solaris installation program to use when partitioning default is specified (by default, the installation program uses all the operational disks on the system). disk_name must be specified in the form cxtydz or cydz, for example, c0t0d0.
If you specify the usedisk profile keyword in a profile, the Solaris installation program will only use the disks that you specify with the usedisk profile keyword.
Note -
You cannot specify the usedisk keyword and the dontuse keyword in the same profile.
