# profile keywords profile values
[This profile keyword is required in every profile.] install_type initial_install
[This profile keyword defines that the system will be installed as a standalone system.] system_type standalone
[The file system slices are determined by the software to be installed (default value); however, the size of swap is set to 60 Mbytes and is installed on any disk (any value). The standard and OpenWindows man pages are mounted from the file server, s_ref, on the network.] partitioning default
filesys any 60 swap # specify size of /swap
filesys s_ref:/usr/share/man - /usr/share/man ro
filesys s_ref:/usr/openwin/share/man -
/usr/openwin/share/man ro,quota
[The developer software group (SUNWCprog) is installed on the system.] cluster SUNWCprog
[Because the man pages are being mounted remotely, those packages are selected not to be installed on the system; however, the packages containing the OPEN LOOK and X Window System demo programs and images are selected to be installed on the system.] package SUNWman delete
package SUNWolman delete
package SUNWxwman delete
package SUNWoldem add
package SUNWxwdem add
package SUNWoldim add
package SUNWxwdim add
