Open a new text file (with a descriptive name) using the editor of your choice.
You can create a new profile or edit one of the sample profiles in the JumpStart directory you created.
The name of a profile should reflect how it will install the Solaris software on a system (for example, basic_install, eng_profile, or user_profile).
Add profile keywords and profile values to the profile.
Refer to the following information as you edit the profile:
Save the profile into the JumpStart directory.
A profile should be owned by root and have permissions equal to 644.
Test the profile (optional).
See "Testing a Profile" for detailed information.
This completes the procedure to create a profile. After you've created all your profiles, go to "Validating the rules File".
