isa_bits 64 | 32 |
isa_bits determines whether 64-bit or 32-bit Solaris packages are installed. Valid values are 64 and 32. If you do not set this keyword, the installation program installs the default packages. The default for UltraSPARC systems is 64-bit packages. For all other systems, the default is 32-bit packages.
isa_bits is a new keyword. If you use it, you must also use the latest check script in the Solaris_2.7/Misc/jumpstart_sample directory on the Solaris CD.
