filesys slice size [file_system] [optional_parameters] |
This instance of filesys creates local file systems during the installation. You can specify filesys more than once.
slice - Choose one of the following:
any - The Solaris installation program places the file system on any disk.
any cannot be specified when size is existing, all, free, start:size, or ignore.
cwtxdysz or cxdysz - The disk slice where the Solaris installation program places the file system, for example, c0t0d0s0.
rootdisk.sn - The variable that contains the value for the system's root disk, which is determined by the Solaris installation program (described in "How the System's Root Disk Is Determined"). The sn suffix indicates a specific slice on the disk.
size - Choose one of the following:
num - The size of the file system is set to num (in Mbytes).
existing - The current size of the existing file system is used.
When using this value, you can change the name of an existing slice by specifying file_system as a different mount_pt_name.
auto - The size of the file system is automatically determined and depends on the selected software.
all - The specified slice uses the entire disk for the file system. When you specify this value, no other file systems can reside on the specified disk.
free - The remaining unused space on the disk is used for the file system.
If free is used as the value to filesys, it must be the last filesys entry in a profile.
start:size - The file system is explicitly partitioned: start is the cylinder where the slice begins; size is the number of cylinders for the slice.
file_system - You can use this optional value when slice is specified as any or cwtxdysz. If file_system is not specified, unnamed is set by default, but then you can't specify the optional_parameters value. Choose one of the following:
mount_pt_name - The file system's mount point name, for example, /var.
swap - The specified slice is used as swap.
overlap - The specified slice is defined as a representation of a disk region (VTOC value is V_BACKUP). By default, slice 2 is an overlap slice that is a representation of the whole disk.
overlap can be specified only when size is existing, all, or start:size.
unnamed - The specified slice is defined as a raw slice, so slice does not have a mount point name. If file_system is not specified, unnamed is set by default.
ignore - The specified slice is not used or recognized by the Solaris installation program. This can be used to ignore a file system on a disk during an installation, so the Solaris installation program can create a new file system on the same disk with the same name. ignore can be used only when partitioning existing is specified.
optional_parameters - Choose one of the following:
preserve - The file system on the specified slice is preserved.
preserve can be specified only when size is existing and slice is cwtxdysz.
mount_options - One or more mount options (-o option of the mount(1M) command) that are added to the /etc/vfstab entry for the specified mount_pt_name.
If you need to specify more than one mount option, the mount options must be separated by commas and no spaces. For example: ro,quota
