locale locale_name |
locale can be used with both the initial installation and upgrade options.
locale designates which locale packages should be installed (or added for upgrade) for the specified locale_name. The locale_name values are the same used for the $LANG environment variable. See Appendix E, Locale Values for a list of valid locale values.
If you have preconfigured a default locale, it is automatically installed. The English language packages are installed by default.
You can specify a locale keyword for each locale you need to add to a system.
