Problem |
How to Fix the Problem |
x86-based systems only. After setting up an install server and configuring the system to install over the network, the system still does not boot. |
Be sure the tftpd daemon is running on the install server. Type the following command and press Return:
If this command does not return a line indicating the rpld daemon is running, execute the following command:
After making this change, try booting the system again. |
