WARNING: getfile: RPC failed: error 5 (RPC Timed out). |
No network boot server. Unable to install the system. See installation instructions. |
Problem |
How to Fix the Problem |
SPARC based systems only. This error occurs on a system that you are attempting to install over the network. The system is not set up properly. |
Make sure you set up the system to install over the network (see "Setting Up Systems to Be Installed Over the Network"). |
prom_panic: Could not mount filesystem |
Problem |
SPARC based systems only. This error occurs when you are doing a network installation, but the boot software cannot locate the Solaris installation image (either the Solaris CD or a copy of the Solaris CD on the install server). |
Make sure that the installation software is mounted and shared. If installing from the install server's CD-ROM drive, make sure the Solaris CD is inserted in the CD-ROM drive, is mounted, and is shared in the /etc/dfs/dfstab file. If installing from a copy of the Solaris CD on the install server's disk, make sure the directory path to the copy is shared in the /etc/dfs/dfstab file. |
Timeout waiting for ARP/RARP packet... |
ip: joining multicasts failed on tr0 - will use link layer broadcasts for multicast |
Requesting Internet address for Ethernet_Address |
Problem |
x86-based systems only. The client is trying to boot over the network, but it cannot find a system that knows about it. |
Verify the system's host name is in the NIS or NIS+ name service. If the system's host name is in the NIS or NIS+ name service, and the system continues to print this error message, try rebooting. |
RPC: Timed out No bootparams (whoami) server responding; still trying... |
Still trying to find a RPL server... |
Problem |
x86-based systems only. The system is trying to boot over the network, but the server is not set up to boot this system. |
On the install server, execute add_install_client for the system to be installed. The add_install_client command sets up an /rplboot directory, which contains the necessary network boot program. |
