NFS Administration Guide
Planning for WebNFS Access
To use the WebNFS functionality, you first need an application capable of running and loading an NFS URL (for example, nfs://server/path). The next step is to choose the file system that will be exported for WebNFS access. If the application is web browsing, often the document root for the web server is used. Several factors need to be considered when choosing a file system to export for WebNFS access.
  1. Each server has one public file handle that by default is associated with the server's root file system. The path in an NFS URL is evaluated relative to the directory with which the public file handle is associated. If the path leads to a file or directory within an exported file system, then the server provides access. You can use the -public option of the share command to associate the public file handle with a specific exported directory. Using this option allows URLs to be relative to the shared file system rather than to the servers' root file system. By default the public file handle points to the root file system, but this file handle does not allow web access unless the root file system is shared.
  2. The WebNFS environment allows users who already have mount privileges to access files through a browser regardless of whether the file system is exported using the -public option. Because users already have access to these files through the NFS setup, this should not create any additional security risk. You only need to share a file system using the -public option if users who cannot mount the file system need to use WebNFS access.
  3. File systems that are already open to the public make good candidates for using the -public option, like the top directory in an ftp archive or the main URL directory for a web site.
  4. You can use the -index option with the share command to force the loading of an HTML file instead of listing the directory when an NFS URL is accessed.
    After a file system is chosen, review the files and set access permissions to restrict viewing of files or directories as needed. Establish the permissions as appropriate for any NFS file system that is being shared. For many sites, 755 permissions for directories and 644 permissions for files provides the correct level of access.
    Additional factors need to be considered if both NFS and HTTP URLs are going to be used to access one Web site. These are described in "WebNFS Limitations With Web Browser Use".
