Users can create a .forward file in their home directories that sendmail uses to temporarily redirect mail or send mail to a custom set of programs without consulting a system administrator. When troubleshooting mail problems, particularly problems with mail not being delivered to the expected address, always check the user's home directory for a .forward file.
A common mistake users make is to put a .forward file in the home directory of host1 that forwards mail to user@host2. When the mail gets to host2, sendmail looks up user in the NIS or NIS+ aliases and sends the message back to user@host1, resulting in a loop, and more bounced mail.
The root and bin accounts should never have .forward files. Creating these files will create a large security hole. If necessary, forward mail using the aliases file instead.
In order for a .forward file to be consulted during the delivery of mail, the file must be writable only by the owner of the file. This prevents other users from breaking security. In addition, the paths leading up to the home directory must be owned and writable by root only. In particular, if a .forward file is in /export/home/terry, then /export and /export/home must be owned and writable only by root. The actual home directory should be writable only by the user. Other restrictions on a .forward file are that the file cannot be a symbolic link and cannot have more than one hard link.
In addition to the standard .forward file, a .forward.hostname file can be created to redirect mail sent to a specific host. For example, if a user's alias has changed from a sandy@phoenix.eng.acme.com to sandy@eng.acme.com, then it might be nice to place a .forward.phoenix file in the home directory for sandy.
% cat .forward.phoenix sandy@eng.acme.com "|/usr/bin/vacation sandy" % cat .vacation.msg From: sandy@eng.acme.com (via the vacation program) Subject: my alias has changed My alias has changed to sandy@eng.acme.com. Please use this alias in the future. The mail that I just received from you has been forwarded to my new address. Sandy |
This allows for the mail to be forwarded to the correct place while also notifying the sender of the alias change. Notice that since the vacation program allows only one message file, so this can be done for only one message at a time. However, if the message is not host-specific, one vacation message file can be used by .forward files for many hosts.
Another extension to the forwarding mechanism is the .forward+detail file. The detail string can be any sequence of characters as long as no operator characters are used. The operator characters are .:%&!^[]+. Using a file like this can make it possible to determine if someone else is giving your email address away. For instance, if a user told someone to use the email address sandy+test1@eng.acme.com, the user would be able to identify any future mail that was delivered to this alias. By default, any mail sent to sandy+test1@eng.acme.com alias is checked against the alias and .forward+detail files. If there are no matches, then the mail falls back to delivery to sandy@eng.acme.com, but the user is able to see a change in the To: header in their mail.
