Need to restore different versions of files (for example, file systems used for word processing)
This schedule saves all files modified that day, as well as those files still on disk that were modified since the last backup of a lower level. However, with this schedule you should use a different tape each day because a file changed on Tuesday, and again on Thursday, goes onto Friday's lower-level backup looking like it did Thursday night--not Tuesday night. If a user needs the Tuesday version, you cannot restore it unless you have a Tuesday backup tape (or a Wednesday backup tape). Similarly, a file that is present on Tuesday and Wednesday, but removed on Thursday, does not appear on the Friday lower-level backup.
Are backing up a number of file systems on the same server
Consider offsetting the schedule for different file systems.
This way you're not doing all level 0 backups on the same day.
