Table 36-1 lists tasks you cannot perform with the ufsdump command.
Table 36-1 Tasks You Cannot Perform With the ufsdump Command|
The ufsdump Command Does Not ... |
Comments |
Automatically calculate the number of tapes or diskettes needed for backing up file systems |
You can use the dry run mode (S option) to determine the amount of space that is needed before actually backing up file systems. |
Provide built-in error checking to minimize problems when backing up an active file system |
Enable you to back up files that are remotely mounted from a server |
Files on the server must be backed up on the server itself. Users are denied permission to run ufsdump on files they own that are located on a server. |
